Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Tue Apr 04, 2006 11:16 am
the auto drive shaft will not work with the manual transmission.
the input shaft of the driveshaft is completely different to go into the auto
what you maybe able to do is use the front section of a stock manual driveshaft and bolt it to the rear auto section.
i would much rather get the entire manual driveshaft since it was balanced together
i have done 2 5spd swaps personally
