will the trans from a 240sx ka24de fit a 2001 frontier?
can i use all
-aftermarket clutches, flywheels, etc. for a 240sx on a 2001 frontier?
-aftermarket manifolds, internals, etc. for a 340sx on a 2001 frontier?
Postby
seang »
https://forums.nicoclub.com/seang-u122444.htmlFri Jul 08, 2011 9:39 am
You might want to look for info on the "white bunny" clutch setup that many owners use on their 240's. I think it might be a truck flywheel/clutch since truck have 15mm more friction surface than a stock 240 unit, but I am not sure of every detail that's why I suggested you search.
I think the trans mount may be different, but its easy enough to adapt it into place. Driveshaft may need to be different length... but as far as mounting the engine to the trans... no problem.
