Somebody lied to you! It's not just a bolt on affair as the CA and KAs block are different, so no, you cannot bolt up a KA's transmission to CA block. However, you can use the KA's gearbox and attach it to CA's bellhousing.Top Speed Coupe wrote:I was told the other day I could bolt a KA transmission on a CA with no problem Anyone here of this?
and even this is harder than many people make it out to be! i'm still in the process of trying to swap my CA gearbox to a KA bellhousing for my s12! you don't just unbolt the bellhousing, and slide it right off...boost_boy wrote: you can use the KA's gearbox and attach it to CA's bellhousing.
Trust me Sean, I of all people know this as all my gearboxes are hybrid variants. They cost me a small fortune to have and it's not just change the bellhousing, either. I say find your own road and experiment .NeedCAforS13 wrote:
Sean
