ka24de transmission mated with sr20det?
Deadrodent
Car: 1992 240sx hatchback
can i use my old ka transmission and just get a maxima clutch? my sr's transmission is making a horrible whine/growl noise that just keeps getting louder...it's probably bearings failing so the transmission will most likely blow up soon...i've heard of people using their ka trannys and then i've heard the complete opposite....
xero1
Car: 08 Altima Coupe
you have to swap the bellhousing(i think)
Hijacker
Car: '92 240sx Convertible
'94 F-150
the bellhousings are different. you should be able to swap the KA gearbox onto the SR bellhousing.
Cyberkreig
Car: 1993 Nissan 240SX SR
Swap the bellhousing and you are all set. I'm living proof.
Deadrodent
can i use the ka's clutch? i have a ACT xtreme pressure plate and street/strip friction disc in my old ka transmission...i've heard the sr's use a maxima sized clutch tho?
TheSparo
don't use a KA clutch... there is a reason why they make them for SR's but yea at least get a maxima clutch, it's not difficult to find SR clutches anymore. And yes you can swap the bellhousing, i did a write up on it on zilvia and or 240sxforums a while back so you could check there under "thesparo"
