slowfkncar »
https://forums.nicoclub.com/slowfkncar-u66525.html
Wed Jun 06, 2007 8:25 pm
i changed my cam sprockets
now the car runs like sh*tthere is much less power compared to before.
i cant even spin the tires in 1st gear anymore.
so my question is.
is it possible for the upper chain to slip without the cam sprockets installed??
my camshaft sprockets line up at TDC EXACTLY how the JWT picture shows it.now the circle mark on the sprocket lines up in between the chain teeth instead of in the chain teeth
if i turn the crank i cant tell if my timing is off by a tooth or not because at TDC its perfect OR i can turn the crank clockwise a bit (20 degrees?) and the cams are still at TDC unless i turn it any more then 20degrees then the cam starts to move.
should i make it so that the cams already start to turn when turning the crank from TDC?
its really pissing me off, my exhaust has this unburnt fuel smell.
half throttle accelerates more then full throttle. my idle is going up and down.
i hope someone can help!
