KA24DE Timing help please
failwagon
Car: 91 s13 se coupe
ok the crank is definately at tdc on cylinder 1. its at the 2nd mark on the pulley and i checked with a screw driver.the timing chain skipped a tooth a couple days ago and that's why i'm fixing it until i can throw another kit oni think this timing in correct except i still couldn't get the motor to start. distibutor had the rotor pointing right at the first cylinder plug wire.
i guess its possible i have bent valves but that wouldnt stop the motor from running. just a compression loss right?
any help is much appreciated.thanks guys
failwagon
bumpp. i need an answer fast
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Dont bump, its a forum not a service. Help will come, did you check the stickes and search I am looking for you as well now.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Searched KA24DE TDC and found this. zerothread?id=426685 And from the stickies zerothread?id=255023
