Can anyone help me ? I have a fully built ka24de all parts fromka24de.com ,valve train also, jimwolf cams, jim wolf ecu etc. My idle vacuum is 14-16 lbs and sometimes on my wideband it will idle at 14.4 but will go to 12.3-13.3 timing is good , fuel pressure is correct , idle speed is fine but will sometimes go into 680-710rpm but it will normally be at 780-800 . It worries me , I only have 1700 miles on new motor. will the jimwolf cams and new valve train make the vaccuum go up a few lbs? or is it maybe a air leak and how can i check it? I have a buddy that just modded a sr20det manifold and stock t25 and has it on his stock ka24de motor and his vaccuum is at 17 18lbs. Any input will be appreciated . At 10lbs of boost it still will run rich 11.3 -10.1 I do not know what it could be . thanks for info.
