The one I'm doing, I used an air die grinder. There are some pics of the carbide bit I used and the little flapper wheel. The carbide bit is 1/4" shank for my die grinder. The flapper wheel gimmick is 1/8" for my electric dremel. Air Grinders are the bomb because you can bog them down to nothing, and they wont burn up. A dremel tool will catch on fire if you bog it down too much. Plus they don't like when little pieces of metal get in there and make contact with the brushes. I used my dremel to smooth and polish because there isn't really a load on it when you do that. But my dremel burnt the hell up for the reason I just said.. Metal in brushes = bad.And depending on what air grinder you get, you can get a front exhaust one that will blow all the s*** out of the way so you can see what you're doing. I would also suggest getting a little LED flexible light like the one I have in the pictures. SO much help to see what the hell you're doing. And I would go for it man. Especially if you have an extra head laying around. It's not really that hard, and the first of second head you ever do will actually be fun. After that, you will dread ever doing it again.babowc wrote:is this on an air die grinder?maybe i should take my spare head off and do this..couldnt you achieve the same thing with an electric dremel? lmk! i'll go take the head off.
...ok I'm done..
