milto0n »
https://forums.nicoclub.com/milto0n-u172657.html
Sun Feb 10, 2013 3:16 pm
Make sure car is running swimmingly in current naturally aspirated state; boost will only exacerbate any existing problems. Start now by gathering "prerequisite" parts. By this I mean parts you will need even before adding turbo namely a 255lph fuel pump, adjustable fuel pressure regulator W/ gauge, and gauges (boost, oil press, egt, afr, whatever your heart desires) Make sure again that everything is running well once installed. From this point out it's a matter of what you are personally trying to achieve (ie size turbo, tuninig, again whatever your heart desires. Sounds like you have been doing your research so just continue expanding your turbo knowledge to make sure you are as comfortable as possible doing the install. Good luck!
