Ka24de swap Wiring
2_slo
Car: 89 coupe w/95 engine/trans
HI, do any of you guys happen to know where there is a diagram of exactly what wires need to be spliced where? Or do i have to follow the diagram for each car and figure out myself? I swapped a 95 engine/trans into my 89 and all i need is to get er' wired in.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Ouch, you're definately gonna have some fun wiring that into your chasis if you are using the 95's wiring harness. 95's power plug is located under the dash where as the S13 plugs are located in the battery area. You'll have to find the wires that goes to the S13 power plugs and extend them to the appropriate wire. It's not that difficult, if you have both wiring diagrams or even better a pin out, you can just match the wires and extend them to the appropriate spots. Anyway, good luck!
2_slo
thanks for the reply, sounds like im gonna have some fun this weekend
