ka24de swap wiring help!
TDCsylvia
Car: 93 sylvia
I really need your guys help on this one. I have a friend who has a 89 hatchback who I thought brought me everything that was needed to convert from k24e to k24de. The car starts, revs up, but WONT stay on at idle. Im looking at the throttle body and there is no connection coming from the wiring harness. My question is;
1) The throttle body has a 3 pin connector on its side and with a wire plug also with 3 pins attached to it. Is this a zenki throttle boddy or Kouki throttle body?
zachattack_5491
Car: Pignose S13 Redtop SR
I'm not an expert on kouki/zenki differences... but what you're referring too is the throttle position sensor. Get yourself an FSM and adjust it.
TDCsylvia
Car: 93 sylvia
No FSM needed, I figured it out. The wiring they gave him did not have the wiring for the tps, which was sending the car to safe mode because the ecu wasn't getting the signal. For anyone buying swaps on craigslist, be careful and not pay much for it because you can compression test but whether the motor will smoke or not can't be checked. Thanks for the help.
