:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Sat Feb 07, 2004 8:23 pm
OBDI, OBDII, none of that matters...!!!
If you retain your original intake manifold, exhaust manifold or header, and only use the head/block from thenew motor, you'll be set.
Only stuff actually on the block is the PCV valve (change it if you want to keep it, or put a vent tube on it) and the knock sensor (plug is same for S13 and S14)...
That way you use the same TB, sesnors, harness, ECU, blah, blah, blah...but have a newer shortblock. I'd suggest swapping cams if it's an S14 motor going into an S13...the cam profile is better.
And for the auto engine thing...yes. Remove pilot bushing from auto transmission (it's stuffed into the end of the crank), swap over adapter plate, mount flywheel, bolt on, push in new 5-speed pilot bushing (much smaller), bolt on transmission. Easy.
Later - Brian
