SlydWeis »
https://forums.nicoclub.com/slydweis-u49692.html
Tue Apr 03, 2007 1:38 pm
I have done some searching and nothing really hits the nail on the head.
I bought a 1990 240SX with the SOHC and manual transmission in it.
I gutted the car, pulled the motor and transmission.92 motor was originally connected to an auto transmission.Took the flywheel off the SOHC and put it on the DOHC.Put on new brakes and clutch.Swapped in a 1992 KA24DE with the 92 harness and ECU.The person that owned the motor before I did put on a new head and water pump.I removed the vacuum lines from the carbon canister, blocked off the EGR, removed the vacuum solenoids on the back of the motor.Ran a single vacuum line from the manifold to the FPR.The swirl control valves are open. The IAC works fine.I setup up the timing, it's perfect.I removed the A/C compressor and PS pump. Made a custom bracket and pulley setup for the water pump.I used the old coil, water temp sensor and starter.Car starts up fine, runs fine, but blows black smoke, it's running extremely rich.I unplugged the MAFS, water temp sensor, O2 sensor, and TPS, it runs the same regardless.New plugs, plug wires, cap, rotor, fuel pump, and fuel filter. Still the same problem.Im wondering if it could be the injectors, FPR, or maybe I need to use a new coil.The higher the RPMs the more it smokes. I can drive it, but I have a smoke screen with me at all times.
Any help is appreciated.
Modified by SlydWeis at 4:49 PM 4/3/2007
Modified by SlydWeis at 4:50 PM 4/3/2007
