Ka24de swap need help
Nickcastro
Alright I just swapped out my KA24E out if my 90 240 for a KA24DE and now it won't start . When I put the key in the ignition and and try turn it on all the elecrtical shuts off. In order for the electrical to come back on is to unplug then plug the battery back in. I have no idea what the problem is. Please help me.
project-x
Car: 1990 240sx
sounds like a short somewhere check all your wires and make sure you battery has a full charge
DALAZ_68
Car: 90' 240sx CA18det
grounding issue...did u check for TDC
Nickcastro
Yeah thanks I found what it was. My stater wires were on the wrong sides and I had a ground wire on it. Thanks.
