KA24DE Swap into S13...Different Driveshaft?
rlee02135
Car: 2004 C32 AMG, 2005 Ducati 749, 1990 240SX Hatch
I have a 1990 S13 that came with the SOHC, 5spd. I'm trying to swap in the DOHC motor, but the drive shaft doesn't seem to fit. It looks like the bolts are getting in the way. Any ideas? I'll get some pics up soon.
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
it might take a little massaging but the driveshafts are the same except you cant use an auto driveshaft on a 5 speed. are you sure the driveshaft is all the way in the back if the transmission?
rlee02135
darens13 wrote:it might take a little massaging but the driveshafts are the same except you cant use an auto driveshaft on a 5 speed. are you sure the driveshaft is all the way in the back if the transmission?
it turned out to be the black dust cover that comes on the S14 trannys, it got in the way of the bolts on my S13 driveshaft. thanks though
