ka24de swap help
NismoGreg
Car: '93 s13 fastback se, '87 200sx se v6,'91 integra ls
Is a ka24de from an automatic transmission compatible with a 5-speed transmission? Are the input shafts the same on both trannys?
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
all that has to be swapped is the flywheel and bolts
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
also you the automatic engine has a pilot converter, you need to take that out and put in a pilot bushing from a 5sp KA. my 96 KA came from an automatic, and my car's a 5spd.
~swave
ultimatuc
Car: fast cars, big trucks, sluts
I have a motor from an auto in my 5 speed. I didnt change the pilot bearing and it works just fine. However asleep altima and I are still unsure if the input shaft even stabs the crankshaft on the altima.
Asleep Altima
Car: Turbo Altima, SR'd S13
i was talking about this today with someone, and im starting to think that after a certain year, the input shaft design was changed... maybe rev could verify this for me? im thinking 97.5 and later are different...
