ka24de swap help
nics fairlady
Car: 1973 240z
im swaping a ka into my 240z and was wondering how much of the smog and vacuum componets i can take off. i also have a q45 throttle body and obviously the throttle body is quite a bit bigger does anyone know of a special mount or bracket that i need to use it?
thrasherx89
Car: 90 hatch (91 dohc, tein, z32, ss, injen, energy, b &m)
240z beautiful
you can take off all the the egr stuff
you can plug them up at the exhaust manifold
pull all the sensors from behind the head
plug the egr valve or remove it and plug it on the manifold
remove the accumulation box thing
block all those little rubber lines from below the throttle body
basically it all goes
nics fairlady
Car: 1973 240z
sweet thanks alot
