KA24DE Starter Spinning Free
Hatchman
Car: 96 s14 zenki, 89 s13 hatch (sold)
Hey guys if anyone could help me out with this i would deeply appreciate it.I swapped a 92 kade into my 89 hatch and i got everything all bolted in and wired up and i go to start it and nothing happened besides my fuel pump kicking on.I read somewhere that a guy just touched the two starter grounds together with a big screwdriver to start his car for a while so i tried that and the starter just spins without catching the flywheel.I swapped out the starter with one that i know works and its still the same deal anybody have any ideas?Also i have an aftermarket flywheel.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The teeth on the starter are not engaging the flywheel. Either wrong starter or the flywheel is not correct for your application. I'd suspect the latter because you already swapped the starter with a known good one and it does the same thing.
Hatchman
It is an f1 flywheel for a ka24de i did a little research and it could possibly be the little blue relay beside the battery has anyone else had this problem?
Rev_D21
I am going to say it's not the relay. If the starter is spinning but not engaging the flywheel and you know the starter is good then something is wrong with the flywheel. The relay may be causing you to have to jump the starter to get it turning but once again, if it turns but fails to engage the flywheel you have other problems going on.
Hatchman
Thanks for the quick replies and well it turns out i'm a dumbass the little button thing on the clutch pedal popped out so it wasn't pressing the start switch so i fixed that and now the starter just clicks when i try to turn it over i checked all my grounds and they seem to be fine anymore ideas?
Hatchman
Well i got it to crank over but now the injectors arent pulsing so i got new ones and they still arent pulsing i checked all the wiring and it seems fine anybody have any ideas?
bro-d240sx
Car: 1990 nissan 240sx s13
here's the injector trouble diag ill try to type it up.
first disconnect injector harness connectors, turn ignition on, check voltage at terminal (A) and ground, battery voltage should exist. if not check continuity between injector connectors and battery. if good check resistence on injectors it should be (10-15) ohms. if good, check output signal between injector connectors and ecu. your gonna have to check a manual for your injector terminals on your ecu. if not good repair wires, if good you have to check all input signals like crank angle, engine speed, timming, etc...if those check out its the ecu. hope this helps.
Hatchman
I'm pretty sure the wires and injectors are fine because when i plug in the sohc ecu they pulse just fine so i'm confused would that mean my ecu is bad?
