ka24de starter on ka24e???
atlamm66
Car: 1992 240 sx
Does anyone know if it will work they are both s13 not s14....my starter just went out....well i think it is the starter....when i went to go start my car(s13 ka24e) it was acting like the battery was dead(turning slow) and then it started so i let it run for a min then went even slower the 2nd time. so i let it run for about 5 mins and went to go start again for the 3rd time and it dosent start(wont even budge). so i figuured my alt. was messed up but my car runs PERFECTLY when push started. all the lights work and everything has full power.so i guess the rules out the alt. and battery. so my guess was the starter but back to the question...will an s13 ka24de stater work on a ka24e? i have 2 of them.
thanks for the help.
tramp_drift240
Car: 1992 240sx SE Coupe
just from the title of this thread, i can answer yes.
im using my single cam ka's starter for my dual cam right now, actually.
though the other question does make me think your battery's dead or about to die. try to jump start it and see if it cranks faster. normally a starter either works or it doesnt.
atlamm66
Car: 1992 240 sx
yeah well the thing is, is that i have been driving all day(by push start) so wither way the batt cant be dead nor low...thats what i dont get:-(
tramp_drift240
well, since the starters are interchangeable, give it a shot. theyre not that hard to replace.
see if that fixes the problem. with any luck, it will.
atlamm66
Car: 1992 240 sx
i cant get that damn bolt off...it is just to weird of a position.AND I AM USING A SWIVELLL grrrrr
atlamm66
Car: 1992 240 sx
ok i got it and yes the starteer is TRASHED...it grinds really really bad when moving...i have 2 though :-)
My RB25
Car: 1990 Nissan 240SX SE
How old is your battery? The normal battery life is anywhere from 4-7 years, usually around 5.
Also easy to do alternator test. Start up your car, get a DVOM (Multimeter), set it to voltage (sorry can't remember AC/DC, I think it's AC. I just know the picture on mine.).
Put the + lead to the + terminal on the battery, - to -, obviously. See what voltage you have. 14.0-15 volts is good. Now turn on the accessories in your car (Radio, rear defroster, high beams, blower (fan)). Now see what the voltage is. Anything below 13v's = New alternator. 13.5 is pushing it. Also normal battery voltage with the car off should be around 12.6 volts.
Hope that helps
atlamm66
Car: 1992 240 sx
no like i said the car runs great when pop started and jumping wont work. so the ^^^ is obsolite.lol. but yeah it was the starter...i fixed it.i just havent heard of one going out just like that(so fast) usually they go out over time. but thanks for all the help.
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
sorry to bring this thread from the dead but my starter just went out and was wondering if an auto starter would work on a maual i have my vert so thats where ima get it from, its out of comission (rod through block) i didnt do it bough it like that
vancouverbc
Car: 1991 240sx
!240RB! wrote:sorry to bring this thread from the dead but my starter just went out and was wondering if an auto starter would work on a maual i have my vert so thats where ima get it from, its out of comission (rod through block) i didnt do it bough it like that
there should not be a difference between an auto and manual. i dont know what years are interchangeable though. all you have to do is check napaonline.com to see if they are the same product numbers.
