So I ended up having to pull the trans off the block to get a chunk of starter from between my flywheen and bellhousing.
So I end up putting it all back together with my original starter and it keeps having the same problem, But I decided to pull the fuel pump fuse and the coil wire off to test the starter/ flywheel engagement and when they are both off the motor spins freely with no problems???????
I cant figure it out, I've got videos I posted on Zilvia maybe you guys can help me figure this out.
http://www.youtube.com/watch?v=9aKZi9lx ... re=mh_lolz
http://www.youtube.com/watch?v=M7Tl8EVf ... ure=relmfu
Here it is without the coil wire or fuse pluged in.
http://www.youtube.com/watch?v=2YjzQ6SW ... ure=relmfu
