KA24DE - SR20 Trans
187drifting
Car: 91" 240sx
is it posible to hook up a sr 5speed to a ka-de? i need to find away to beef up the trans cuz i blow the ka trans every time i go out for to long or to rough. any input would be great
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
If you want a stronger transmission you need to put a Z32 transmission in the car.
lbreevesii
Car: S13 hatch LeMons project - Kaputzen!
BMW E30
Z32 would be stronger, but SR transmission can be done I think. I don't know about the wiring(granted the only wire that really matters is the reverse lights) but you can swap the KA bellhousing onto the SR transmission. I have heard of it being done the other way so when an SR transmission goes out you can buy a cheap KA transmission to put on your SR.
Same method applies to Z32.
187drifting
Car: 91" 240sx
i didnt know a z32 can fit. hell i just might go with that an see if it can handle the abuse
sx moneypit
1986 Toyota MR2
Get the twin turbo transmission ,it will take the abuse.
DuckyD
Car: 1995 240SX
lbreevesii wrote:Same method applies to Z32.
Its not a straight bolt-on thought.http://www.mazworx.com/index.p...=2759Looking at $1100 plus the transmission.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
sx moneypit wrote:Get the twin turbo transmission ,it will take the abuse.
eaither will take the abuse, they have the same input shaft and output shaft size, either will be better then a sr/ka/rb20 gear set.
you can swap the bell housings from a ka to sr or sr to ka to make something work
