KA24DE Specifications
eyecandy
I am looking for KA24DE, and KA24E specifactions, not the normal like compression, strole, bore etc.. Well that can be include but Valve lift, Cam degree, injectors all stuff like that.. Does anyone know where i can find anything like that? I have looked on the net for a few hours and i can not fin anything!!!
Also does any one know where i can find road tests of a S14? LMK Thanks!
quiksilvia
Car: 95 s14 se
whats lmk? the chiltons guide has all that crap, let me know what u want to know and ill see if i have it in the book.
eyecandy
LMK is Let me know
Well basically everyspec for the engine is what i am looking for, i am not sure how it is layed out in the book, but maybe if you scanned the pages or something.. Thanks!
eyecandy
Oh also, i know there is a very small diference in the S13 KA24DE and the S14 KA24DE, if i am not mistaken it is higher compression in the s14, but it still creates the same horsepower..
quiksilvia
Car: 95 s14 se
that i dont have the info for, and i dont really have access to a scanner, but ill see if i can type all the specs up in an email for you, i dont work all day so ill be bored
eyecandy
Thanks! But you do not have to go way out of you way like that..
Nismo_Freak
Car: 89 Nissan 240SX
eyecandy wrote:Oh also, i know there is a very small diference in the S13 KA24DE and the S14 KA24DE, if i am not mistaken it is higher compression in the s14, but it still creates the same horsepower..
- Same static compression (179 psi @ 300 rpm) - Ignition system changed to coil-in-distributer in 94- S14s have laser cut NGK platinum tipped spark plugs OEM- S14s have heavier pistons (hence lower redline) - S14s also have metal backed timing chain guides- S14s are all R134a compatible (earlier S13s are R12 IIRC) - S14s have slightly larger radiators - 96-98 S14s have heated 3 wire O2s
Thats all I can come up with at the moment.
eyecandy
Thanks, But what i do not under stand is my does the s14 ka have the same power as the s13 ka? I belive it have .5 higher compression, or it might be .3.. can't remeber off the top of my head.. could it be ecu, injectors?? hmmm
