KA24DE sounds like a v8 mixed with a import is this right?
DAZ3
Car: 1995 Nissan 240sx
im new to the world of 240s well really all cars cuz im only 16 and i traded my ****ty crx for a s14 cuz i always wanted one - but when i start it up the motor shakes like a v8 and sounds like a built v8 idk how to explain it kinda like its about to stall but fires up again idk ive been working on dirtbikes n stuff a while and this doesnt sound normal to me....is it right?...n i dont wanna hear im a dumbass n if your gonna say that give some advice so i get smarter lol but thanks for the help if i made sense to anyone
darkspoon
Car: 1990 Nissan 240SX X2
1993 Nissan 240SX
Check your compression, check your timing, injectors/spark and your MAF.
Also check your air filter/fuel filter
What happens when you try to rev it?
DAZ3
it revs up like normal maybe a little slower compared to my crx n when i let it idle it shakes the whole car even after i let it warm up...when i rev it up it doesnt sound like an import it sounds more like a muscle with a euro pipe but not loud btw its completely stock
Modified by DAZ3 at 12:30 PM 5/25/2008
darkspoon
1993 Nissan 240SX
yeah definitly look into those few things, see how it goes, and get back to us?
maybe more explanation of the sounds or if there are any other sounds
and is anything coming out the exhaust which shouldnt be?
Nissan240sx_s13
Car: 1990 Nissan 240sx
If you can, videos do wounders.
drunkNun
Car: 90' 240sx coupe////92' nissan pickup
Might have an exhaust leak. I just fixed an exhaust leak on mine and it had the same symptoms. My leak was right where the manifold meets the head. My gasket blew and melted a spark plug wire in half. Would sit and rock the whole car at stop lights and power was gone from only having three cylinders to work with. You might have an exhaust leak also. If you here any ticking noises or anything look for them. Exhaust leaks can make ticking noises.
danielsan
Car: 1991 240sx coupe SE
sounds like a bad injector/s. my brothers coupe had the same problem, at idle it sounded like a subaru and shook the car. if it idles like crap but smooths out when reved then it might be a bad injector.
pull off the spark plug wire on at a time and take note at which one does not cause a difference in idle.
LayNLow240
Car: 92 240 coupe
Also check for vac leaks. That will give you a horrible idle like your describing.
jds13
Car: 1993 240SX SE
I had the same problem you're having in my S13. In my case it was the injectors, you should check those and hopefully that helps.
DAZ3
dnlx5
Car: 91 240sx s13 hatch 5speed sr20de (crashed but still driving)
its gota be a misfire or a really bad vacume leak mabe timing check spark plugs wires and injectors. to see if there working turn the car on then unplug each injector and see if the idle changes if it does that means that one was working. if it doesent it means that one isnt working then plug it back in and try the next one then do the same with the spark plugs tehe
DAZ3
OK ALL THE PLUGS AND WIRES R WORKING CUZ EVERYTIME I UNPLUGED ONE THEN TURNED THE CAR BACK ON IT IDLED WORST I CLEANED THE PLUGS AND IT IMPROVED A LITTLE
got chub
Car: pearl white 95 240sx
check your timing... i can hear ticking in the vid.
oh and maybe you should wait to rev like that after you have built some oil pressure. that almost like starting it with no oil in the car at all.
DAZ3
thanks ill check it today
lfofootball76
Car: 92' 240sx
i had the same thing happen to me and it was the sparkpulg wires.try that
DAZ3
it had a vac. leak thanks everyone its running fine now i need the front half of the drive shaft if anyone knows 95 nissan 240sx
junjun0134x
Car: 93 Nissan 240sx
Im actually having this prob 2 with my s13 but mine doesnt smooth out when i rev it sounds like a harley..it was fine when i drove in the morning but when i came back after a lil bit it started.i checked the spark plugs, the cables, and the disti. cap they all work and i quick checked for vac leaks and didnt find anything... i have a bad coolant temp. sensor that im waiting for a new replacement to arrive and was told that that could be causing my engine to act like its misfiring even though it isnt...what do you guys think?
Modified by junjun0134x at 8:20 AM 6/2/2008
Modified by junjun0134x at 8:29 AM 6/2/2008
