480sx »
https://forums.nicoclub.com/480sx-u50548.html
Wed Dec 12, 2007 7:08 pm
It can be done but will be tricky. You have to keep your EGR system which is usually discarded on a turbo install. Another big problem for you, you wont be able to run a chipped ecu. Your going to have to go with a piggy back like the emanage or safc2. For an OBD2 emissions test its all about your check engine lights. If you throw any, you will fail. Thing is, if you spend eh, i think its like 750-1000 dollars and it still wont fix your codes you can get a voucher and get your car passed regardless of codes. Thats VA law anyway, you really need to do a lot of research before you decide to take the plunge on local emissions laws. Go up to a few shops and talk to their inspectors, ask as many questions as you can.
