pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Mon Mar 16, 2009 1:14 am
Well, speaking from personal experience as I do this for a living we use the brake booster line quite frequently. Gm has their own product called top engine cleaner and it comes in a bottle thats around 16 oz. We do a top engine clean service that consists of getting the engine hot, start it up and pull the brake booster hose off, put the booster line in the bottle and tip it upside down to get the stuff in as quickly as possible, shut the engine off as soon as the bottle is empty, let the engine sit for 10 min, then start the car up and try not to die from the plume of smoke that comes out of the tail pipe, rev the engine up and down until the smoke starts to go away, take the car down the road and just run the $hit out of it for a few miles after it quits smoking, return to the shop and change the oil. Now, this service differs some from the seafoam treatment as it is only run through the intake and is not intended to be put in the tank as it will literally eat up the fuel pump and charcoal canister, nor is it intended to be put in the crankcase. Anyways, the point is there are 2 reasons that a can of seafoam, let alone 1/3 can will not even come close to hydrolocking an engine. First the entire contents of the can are barely enough to fill 1 cylinder let alone spread across 4 to 8 cylinders. Second, when introduced into the engine while running most of the fluid evaporates very quickly turning it into a fog which is compressable. We do have one of those dispensers here that looks like an iv and it is actually hooked up to the brake booster hose as well. I believe that I'm the only person that has ever used the dispenser and that was long long ago. Also, if you simply read the BACK OF THE CAN OF SEAFOAM it will tell you to introduce it into the intake in a steady stream while keeping the engine running, then when you come close to running out dump in the last bit quickly enough to stall the engine and let it sit for about 10 min before restarting. Now, I know that a lot of these products are not what they claim they are, but from a liability standpoint they wouldn't provide instructions that could cause engine damage or they'd be out of business pretty quickly from all of the lawsuits.
