AeonTorpor »
https://forums.nicoclub.com/aeontorpor-u29488.html
Wed May 19, 2010 2:08 am
Ok, so I swapped a newer (94) KA into my car for the blown one (91 original).
I have many new parts in here and it's been running great for the last 6 months.
New:
fuel pump (walbro kit)
fuel filter (z32)
fuel lines (the rubber interconnects)
air filter
spark plugs (single prong)
plug wires
rotor & cap
exhaust mani gasket
and catalytic converter
Again, it's been running like a gem until earlier this month. It began sputtering, it's idle became a bit loopy, slowly it got worse until it became really difficult to turn over. I checked the spark plugs, they had soot on 1&4 most prominently. I measured the ohm rating of the injectors and it seemed as if 2 was dying with a reading of about 24 Ohms and 3 was dead at 300-something Ohms.
I replaced all injectors with those that measured about 11 Ohms (had spares lying around) and it's still bucking a little and it's just a little loopy, I can also smell a strong odor of gas. I checked all vac, gas and electrical connections, they're all fine and connected properly.
The car runs and all, but I'm worried again that this could be an indication of something else. Anyone have any suggestions?
