Dirtyl3um »
https://forums.nicoclub.com/dirtyl3um-u49427.html
Sun Jan 31, 2010 10:40 am
Hey all,
I was hoping some of you who have a more experience could help me out with this problem im having. I bought a 90 240sx with a blown motor, and i put in a motor from a 96.
I got it all wired up and timed and got it to start. I timed it just like my other 240 via checking it with a timing light (which is to spec with the service manual)
Anyway, it wouldnt idle, it will start and if i play with the gas pedal i can keep it alive for as long as ill feather it. The motor is shaking a decent amount and it seems like a misfire, so i take the good plug wires off my other 240 and check. same deal. Checked the spark plugs and none are fouled. Checked to see if any specific cylinder wasnt getting fuel, but they all are.
At this point my buddy and i are wondering if we messed up the timing. so we start messing with it and we found that if we move it one "notch" counterclockwise and turn the distributor as far as it will go clockwise with the bolt in place, it will idle (still like balls mind you).
i thought it might be a ground so i looked at those and they all seem okay? Also all the EGR business is gone and plugged with plates. Not sure how that effects the computer.
The car is running a bit rich, so im pretty sure its misfiring, just not sure why.
Any help or suggestions would be fricking awesome.
Thanks
