Dustin792 »
https://forums.nicoclub.com/dustin792-u125400.html
Thu Feb 05, 2009 6:06 am
Hello everyone , i just bought a 1990 240sx with a ka24de(pretty sure its 91-94 s13 motor). when i bought it sounded like a timing chain rattle (but it ran decent enough to drive around without problems), i opened it up and the top guide wasnt there but the guide on the right was , also the bottom tensioner needed to be replaced. so i ended up replacing both chains(double row) , both tensioners, and both bottom guides and i removed the top side guide( because the top guides were discontinued and are no longer needed). anyways when i replaced the timing i made sure i was on TDC compression stroke with cam lobes facing out. i made all my marks and replaced everything how it was before and torqued everything to specs. replaced covers and pan with no leaks. replaced distributor and made sure it was pointing #1 cylinder at TDC. So when i start the vehicle it runs pretty well at idle then when it starts to warm up it gets bumpy , idle starts to diverse up and down and the engines starts to sound like its choking. i tried to drive it (it moved but it boggles and backfires my friend even fire came out lol) it ended up not starting again, so i removed egi and egi pump relays cranked it , it started and then died , replaced relays then it started up again. i replaced spark plugs. rotor, cap, and fuel filter, and it didnt get better. Also when i bought it came without an egr-bpt valve , just plugged vacuum lines and T splitters for vacuum lines. the clutch slips pretty bad but i dont think that will matetr much. I appreciate any help i have been at this for a week now and have done alot of research and dont know what else to try, any help would be great thanks alot and have a good one
