KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sat Jan 02, 2010 3:16 pm
Ok...am I correct in understanding this is a stock KA setup? No forced induction, spray, etc?
If I'm correct, please follow my instructions below. I don't mean any of it to be rude...but I do know what I'm talkin' about.
Step 1: Understand how a narrowband O2 sensor works. The sensor is designed to "bounce" between full lean and rich when the engine is at idle or part throttle cruise. The ECCS uses this to find an average, and consequently alters the fuel mixture to reach the average stoich burn based on the "bouncing" of the O2 sensor.
Step 2: Remove the narrowband O2 gauge from your car. Toss it in the garbage.
Step 3: Remove the SAFC from your car.
Step 4: Drive it like you stole it and forget about it.
From the factory, the ECCS is calibrated to be a little on the rich side under WOT dyno pulls. However, keep in mind, they're counting on someone using the crappiest gas they can find.
Seriously, best thing you can do is drop the issue and drive the car. You'll enjoy it much more.
