sharkerio_coupe »
https://forums.nicoclub.com/sharkerio-coupe-u93168.html
Thu Oct 30, 2008 3:43 pm
So here's the break down...
my wiring harness somehow got wrapped in the fan. ripped some cables, took out a vacuum line, seized the clutch fan, broke the maf sensor.
so i spliced the wiring, got it all to start up again. the fan was seized so it turned with the engine. but it ran n i could hear the fan all loud. And i would feel a power loss at 4000rpm.
so i replaced the clutch fan, the stock intake, and the carbon canister cuz it broke.
After i replaced all that it ran a little more junk. It smells suuuper rich, idles like **** and wont hold the idle. Plus it doesnt want to rev past 2500, it just bogs out there and lets off a lot of black smoke, if i let go of the gas it shuts off.
so this is what else i then replaced. I cut the harness and spliced on a solid piece with no tears or what not, replaced the broken sensors. still same symptom
then i replaced the coil pack, and the throttle sensor. still same problem
n i just finished replacing the MAF and stiiill the same.
any ideas or suggestions on what it could be? any other info i shud add?
im gonna try n get a camera n maybe put some video of how it runs.
THAAANKS
