InitialDGuy »
https://forums.nicoclub.com/initialdguy-u3043.html
Thu Jul 17, 2003 4:41 pm
Well,
I found and fixed the problem. At first I tested the Coolant Temo Sensor as advised, and found it to be defective. 'Ok' I thought, 'This must be the problem!". Well, I pulled a sensor out of a parts motor I had laying around and installed it. No difference. The car still ran horrible. I even waited until the car had warmed up to the proper levels and tested the replacement sensor to be sure that it actually was working. It tested dead on spec. So, I started poking around the fuel rail and noticed that the No. 4 Injector was leaking. So I spent an hour pulling the fuel rail off and after I pulled the rail, I spotted the problem straight away. The cap on the bottom of the 4th injector was simply NOT there. I mean it was gone, completely. The injector also looked all burnt inside, as opposed to the other 3 injectors, which all looked fine. All of the seals were also all cracked and dried out. I swapped in a different fuel rail w/ 4 nearly new injectors on it, and the car ran like a champ afterwards. I still need to change the oil as I am sure there is some gas in there from the faulty injector dumping fuel in like crazy. I am also going to remove the AIV assembly as the idle is a tad erratic at times and the acceleration is still a little rough right about 3 grand for a few moments. Still, all things considered, I am happy that this turned out to be relatively easy to fix, and that it wasn't a burnt valve or something equally ****ty.
Thanks for your help everyone.
Adam
