ka24de rough first start
futureS13
Car: 1989 240sx
alright i just changed the starter due to a broken housing around the teeth and i changed the timing chain cuz it looked like it was slacking a lot and hadnt been changed for the first 120k( due to dude before me) when i went to start it up for the first time since the new parts it started making a knocking sound and spraying oil over the filter. does anyone have any idea what i might of done wrong? it didnt make any knocking noises at all before i changed the parts so im confused :wtf2:
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Did you set the timing correctly?
Did you mess with the oil pump in any way?
Check EVERYTHING you did once more, then check oil pressure once done to see if engine is still good.
Klits562
Car: white s13 coupe
I would quadtruple check the timing
