fleali88 »
https://forums.nicoclub.com/fleali88-u135413.html
Sat Mar 20, 2010 8:37 am
ok, i dont think ive seen much on doing this but,
Im hearing a knock ( i'll post a video later so you can hear), its a very hard sounding noise, but right now its only between 2-3k and or 3-4k rpms.
my question is, say i drain the oil, remove the x member , remove oil pan, remove oil pick up plate, remove main bearing cap, move all four rods around to see which bearing is gone/bad/spun, simply remove the bad bearings rod cap, (apply lube)insert good bearing, tighten rod cap ( to spec of course lol), re-install all removed parts, fill with oil, start engine. lol
that is just IF the rod bearing/s are in fact bad.
do you think the car would run normally or would it cause alot of problems because i did no honing, measuring, all that math bs lol.
reason i want to do it like this is because i don't want to put any money into this engine, i want it to run until i save up $$ for an sr.
has anyone done this? i need input lol, and ill take a few flame throwers if need be haha. thanks nico.
