JeffHudson92 »
https://forums.nicoclub.com/jeffhudson92-u125656.html
Fri Jan 30, 2009 6:13 pm
i've been looking into rebuilding my ka for a long time and have come up with what i know i need but i still have a few questions.
OEM gasket kitarp headstudsoem piston ringsand bearings
i was going to do a timing rebuild too but i just read a bunch of stuff with guys saying that the timing chain never needs to be replaced, and that its usually just the guides and tensioners that break. So if i'm tearing it all apart anyways should i redo the timing even if there is nothing wrong with it? if i decide to not rebuild the timing will i still need to disassemble it to replace gaskets?
i'm rebuilding just to fix an oil leak, improve compression, and generally prepare for a turbo setup. is there anything else i should do while i'm rebuilding? My friend with a supra and some mechanical experience recommended that i get some cams, what do you guys think.
i'm totally open to advice. thanks in advance.
-jeff
been lurking for a while now too, finally joined.
