180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed May 16, 2007 7:06 pm
sorry, different and KA-T doesn't exist anymore.
Don't see why you couldn't rebuild it at a shop for a couple hundred bucks if you buy the rings, bearings, gasket kits and so on. Expect a full rebuild at a machinist to run ball park 2k parts and labor. Turbos alone will run a little more than 1k if you buy new. You'll also need the manifolds, injectors, fuel pump, ecu, intercooler and pipes to be made or bought. Expect that to fill up the rest of that 3k remaining in your budget. That's a fairly conservative budget. You can shop around to buy premade parts from guys trying to get back on the road from their blow ups or guys looking to go farther than they've currently got. So that price will vary a bit. Don't buy cheap crap though. You'll pay for it in the end. You'll be doing the install of that rebuilt motor and transmission along with the assembly of the turbo parts onto the short block.
