Brandon_saroka »
https://forums.nicoclub.com/brandon-saroka-u213424.html
Sun Dec 16, 2012 9:27 am
Ok, so i pulled my ka24de out out my 91 s13. And rebuilt it with my buddys old block. I have evetything from my motor put on this longblock.(old motor was blown) and built it up. Put everything back and hooked everything up. No good. Rolls over but no start. It is getting spark, and getting fuel. No compression leak, and timing is right. Dizzy is also set correctly. Yet no luck. Also has the same ecu as the old motor. Only new thing is gaskets, clutch, flywheel, and block. Surfaced the head. Block ran before i had it.
