KA24DE - Rebuild or Replace?
thomasjamal
Car: 93 coupe
So my KA currently has about 205,000 miles and most likely bad piston rings (a compression test tomorrow will confirm this). It's been burning oil since I got it and has only gotten worse.
So I'm trying to decide whether to rebuild my motor or buy another lower mileage KA and replace the head gasket and main seals.
Obviously my main concerns are keeping cost down relative to reliability.
Let me know what you think and why.
BTW, I should probably request that Nzmoman weigh in on this since I'm counting on him helping me do it...
FYI, I'm currently considering a KA with 120k miles that runs well with a MT for $350.
Modified by thomasjamal at 10:30 AM 4/24/2007
gumby74
A good rebuild is the only sensible choice. I applaud the engine for not crapping a rod bearing. You can have your engine rebuilt for well under a grand if you wrench yourself. Pay a couple extra $$ for Clevite bearings, take your time measuring tolerances, and you will be good to go for another 200K.Thats my opinion anyway. Good luck.
xSeraphin
Car: 1989 240SX XE C
1992 240SX SE FB
2000 Accord EX C
Since you're sticking with the KA there's no sense in paying for what you already have. You can get some good rebuild kits for around $300 which is great if you can do the work yourself. Buying another KA will cost you at least $200 if you can find a really good deal but it'll still probably need to be rebuilt. You might be able to find a drop in for around $700 but you'll still want to pull it apart and see what kind of condition it's in unless it has a guarantee or warranty with it.
thomasjamal
Car: 93 coupe
Anybody else have any thoughts on this?
thomasjamal
Car: 93 coupe
bump
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
i vote rebuild.My KA has 185k on it. My plans are currently to build and turbo it. There's a wealth of swap engines, but i just think it's cooler to have the stock engine rebuilt and pushing big numbers, then swapping in a monster powerplant.
If you only want it to run better and stop burning oil, a simple ring and seal rebuild is pretty cheap and will be better then buying a new engine.
TheOne
Car: 93 240sx FB
if you have the knowledge & means to rebuild the engine, i'd do so.(i've probably rebuilt/replaced 6 ka's,lol, 4 bein to my car)
but if you don't know, just go ahead and get that engine, save yours for later on to get it fully built.
Delerium
Car: 1991 Nissan 240SX
Im with TheOne on this one. If you have the know how rebuild it because it will be more reliable, but on the other hand you could drop in the replacement and build up your old engine over time and then drop it back in when the other one craps out...or before if you wish.
Soravia
Car: 2003 Audi A4 1.8T
You'll need a garage and a bunch of time to rebuild. I see this mechanic rebuilding a Supra engine from ground-up and he's been at it for over a week now, working on it every other evening. But it seems to involve a lot of things like painting and stuff to the engine, not just replacement parts.
Personally I would get a low milage NA SR20DE but that's my taste.
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
the ka is a horse, so id say rebuild. I did my truck motor which is a toyota.... no comments plz.. for like 400 and its almost all full race
160 for boring .010 over and .010 oversize ringskept stock pistonslike 30 for all clevite77 main bearingsanother 30 for rod bearingslike 4 tubes of rtv freee for me im a mechaic, i charged my shopgasket set ~110 (this gave me fr ad rear main seals)valve sels ~20and i would have been done but...i added-blueprinted rods and pistons free just takes time and a medical scale-cam 100 bucks-valves 90-double valve springs 85-titanium retainers 45-shims 25-guides 12--port polish, lapping valves, oversizing the valves and spring seats-275
was it worth it? eh.... i know its reliable, has more power than stock and sounds cool when it idles.
Would i do all that again? no, id cam it and get oem springs and leave the valves.
its a toyota 22re, same engine as an ae86.
so if you look at mine, i assembled it myself and had a shop do the machining on the block and head. basically i could have done it for 350 and had it good as new, but i had money to burn.
Soravia
I thought AE86 had a 4AGE.
funigui
depends on the year, the true blue ae86 yes is the 4age, but toyota corolla gt-s`s had 22re`s as well
