Gramentz »
https://forums.nicoclub.com/gramentz-u40915.html
Mon Sep 18, 2006 2:14 am
Order your bearings from either your local nissan dealership or from courtesy parts. I found courtesy parts to be a lot cheaper than local, but I think it all depends on local rates. The crank you can take to a reputable machine shop to get balanced...same with the block to get bored and re-honed etc. Pistons and rods you can order from any advertiser...the pistons generally come with the pins and rings.
Order your pistons before you get your machine work done so they have the piston(s) while they're working on your block. Be sure to get upgraded head studs/ head gasket while you're at it also.
