I will have to agree with you on the rings. I can put a can of rislone in with the oil and the smoke will disappear for a few months. The stuff actually lasted for over 12k miles before the smoke came back this time. However, I can tell that I seem to be loosing a bit of HP, the get up and go is not as good as it use to be.KoopaTroopa wrote:I'm currently rebuilding my 200+k ka24de also. I'm in the middle of pulling the engine out of the bay/cleaning things up. My advice would be to find a machine shop nearby and talk to them. Sounds to me like all you may need is a valvejob and a new headgasket, unless your rings are going. AMS performance makes a full rebuild kit.
28 MPG, that just blows my mind.NME-s12 wrote:All depends on your level of expertise. If you dont feel comfortable do the rebuild your self i would definitely have a shop perform it. Other wise i have heard great things about the AMS kit. If your looking into Fuel economy+power i would recommend one of 2 things. 1st Have a shop do a sr20 swap with everything stock like it was from japan. so it has a restored look.(sounded like thats what you want from your comment above) With that you will have approximatively 215hp and 28 miles to the gallon highway at 70+mph. 2nd do the rebuild and boost it. This route going cheap as possible with reliable parts looks a little like this list.
s14 turbo $250-$400
Exhaust manifold $200-700
Dump pipe & Down pipe $300ish
Intercooler w/ piping $200-$600
Injectors $250-$400
intake $100-$270
Stand alone ECU or Piggy Back or SR-ECU w/ Rom flash and mod 300-1200
I have seen full sr factory swaps professional done w/ motor and tune up $3800.00
All and all up to you.
Since the engine questions are getting all the attention, I can speak for the quality of the Katzkin leather kit. I did this back in 2004 and also called them and ordered matching material for the door inserts. I needed a bit of assitance with recovering the front seats due to the new material being so tight. But eh finished item is just beautiful and I still love it to this day. They offer an installation kit, but I used simple tools. You can see a bit of my install here:Hithere wrote:As far as the interior, have any of you utilized katzkin leathers, and are they easy to install?
"Assistance" as in Professional, or as in you just needed someone to help you stretch them on etc?scotty-2-forty wrote:Since the engine questions are getting all the attention, I can speak for the quality of the Katzkin leather kit. I did this back in 2004 and also called them and ordered matching material for the door inserts. I needed a bit of assitance with recovering the front seats due to the new material being so tight. But eh finished item is just beautiful and I still love it to this day. They offer an installation kit, but I used simple tools. You can see a bit of my install here:Hithere wrote:As far as the interior, have any of you utilized katzkin leathers, and are they easy to install?
http://www.cardomain.com/ride/400454/4
If you want to do a basic ka rebuild, i would do this:Hithere wrote:At 200k miles the ole 240 has begun to smoke a little.
A year or so ago I had contemplated rebuilding the engine.
Myself and the wife have now decided to do basically refurbish the 240. We are doing new paint, interior, engine.
Would appreciate advice on decent quality rebuild kits.
Would also appreciate advice on boosting the horsepower in an economical fashion. This is an every day driver.
I was also wondering, if the cams and crank spec out to meet factory specs, would any of you reuse them, or would you go for new crank and cams, timing gear etc ?
FIXEDFuture_gohan wrote:
With all that done, get an sr t28 and a 6:1 fmu and run 8psi for the rest of your life.
+1 to AMS rebuildKoopaTroopa wrote:I'm currently rebuilding my 200+k ka24de also. I'm in the middle of pulling the engine out of the bay/cleaning things up. My advice would be to find a machine shop nearby and talk to them. Sounds to me like all you may need is a valvejob and a new headgasket, unless your rings are going. AMS performance makes a full rebuild kit.
but, if you use a t28 to its full potential, his ka will need more than a basic rebuild, with a t25 even at max boost(13psi), he wouldn't need more than a basic rebuild.motoman399 wrote:the t25 is like fat free milk. ya it works but its just not right.
he could get a t28 from a rb25. it has a t3 flange so it will flow more air and its ball bearing so you get that low spool. plus they are cheaper than the sr t28 and just a little more expensive than the t25.
