phuphyter »
https://forums.nicoclub.com/phuphyter-u19167.html
Sun May 22, 2005 2:34 pm
Hehe I'm having trouble with one of my fuel injectors. Your situation sounds exactly what I went through.
Check your fuel injectors. What my uncle did was unplug the electrical connector to each injector one at a time while the car was idling. If unplugging one of them doesn't make a difference in the shakiness, it's most likely that one.
You might need a new injector, new o-rings or both. Me, I had to swap out the dead injector and now am having a slight problem with the o-rings. Autozone doesn't carry the right ones by the way. they only carry the lower ones, which happen to be a different size than stock. I found out the hard way.
If it is your injector, spray the screws with a lot of wd-40 or equivalent long before trying to remove them.
Also do a search for fuel injectors, o-rings, and leaky fuel injectors. I hope this helps
edit: oh and welcome to nico
