ka24de radiator problem please help!!
s14ka24det
i have s14 ka24det . i dont know why everytime the turbo kick in the radiator starting blow bubble inside . its has alot pressure inside the raditor . and its blow out throught the small hose on the top of the radiator , and keep running out the radiator fluit make it over heat if i not refill the radiator. please help me see what wrong with this . i have s14 ka24de motor with s13 camshaft and cp piston , eagle rod , garrett t3/t4 turbo .
Oneandonly212003
Car: 1990 240sx
when you turn of your car tuch the top and the bottom they should be hot if one is way coolder then your radiator is cloged
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
to me this seems like a blown head gasket man..if you have heat and pressure inside your radiator and are loosing fluids to somewhere..then its a strong candidate for a headgasket failure.
theengineguy
Car: 1995 240sx se
i agree with liquid cool, sounds like a blown head gasket, if you water cooled the turbo could be cracked passage. tell tale sign of a blown head is white steem discharge from the tailpipe. and to cover my a$$ sake should mention a cracked head or block will do the same. you can also check under your oil cap to see if you have any milky white or yellowish buildup, this may indicate a coolant leak into the crank case. if all else fails take it to a shop and have them block test it( round 30-40 bucks) that will tell you definatly if you have internal coolant system pass through. best of luck to ya
s14ka24det
s14ka24det
the car runnning fine before i install the turbo . i hear couple people said if blow head gasket the car cant built no boost but my car running 8lbs of boost right now
locoluna825
Car: 90 240sx coupe
yea but you could have blown a certain area of the head gasket making the boost from one of the cylinders bush into a coolant collant . and its really not a wise choice just popping on a turbo without at least freshening up a motor even at 8 pounds.
