ka24de problems
turoki
Car: 92 240sx
hey guys i really need some help with my ka its running like crap here are the symptoms and what i replaced o and its a rebuilt motor with les than 20thou on it
the symptoms im having are these at a idle with the ac on or off the car will be sitting at 700 and all of a sudden the motor shakes and clears up it is getting bad to the point where it dose it every time at a stop light or stop sign also it has really bad throttle response at times and when i hit the throttle it acts like im doing nothing and ill here the exhaust putting then all of a sudden it kicks in and its fine this usually happens after 2k thats where it clears up O and the strange part is that it only happen in the evening this dosent happen in the morning well the shaking dosent but i haven't paid attention to the throttle response ill check it tomorrow morning.
this is what i have changed and done so far are parts that are new
i changed the air filter it was really dirty i cleaned the maf sensor and checked the injectors they has 12ohms all the way across , the tps is new the egr is new and the plugs have few miles on them i also changed the cap and rotor and the fuel filter if anyone could give me a had id really appreciate it thanks
r3v_v3ng3
Car: 91 fastback ka-t
with the a/c on the idle should be at 1k rpm without it would be 700-750.
turoki
Car: 92 240sx
yup your right thats what im getting but im still having no luck any one care to take a stab at this one?
r3v_v3ng3 wrote:with the a/c on the idle should be at 1k rpm without it would be 700-750.
