ka24de problems fuel in oil...help!!!please...
240freak19
Car: 1992 nissan 240sx hatchback
ok i just got the motor timed perfect and idled great until i reved it to 3000rpms and felt like it was hitting a rev limiter and shaking the car to sh*t it wasnt smoking out of the exhaust or anything it was weird i couldnt figure it out at all i turned the car off and checked the oil and it was really thin i took the valve cover off and as soon as it came off it reaked of fuel s bent over and smelt the cams and it smelt like straight up gas whats happening there is fuel in the oil pan and all threw the motor...any1 now whats up???
Cone Junky
Car: S13 fastback
BMW e46 328i
Sounds like one or more of your injectors is leaking.I wouldn't run the motor anymore until you fix the problem and put fresh oil in.
danielsan
Car: 1991 240sx coupe SE
sounds like your maf is toast.
Vegascorbin
Car: 1990 240sx dirt track race car
Just to clarify for you, The MAF has nothing to do with the Fuel in the oil.
The MAF can be the cause of the rough running / cuting out above 3000.
Two seperate problems. Fix the fuel in oil first.
Black on Gold
Is this the first time you've ever noticed the gas smell?
240freak19
ok its cuttin out at 3000 rpms and running like **** but if the injectors are bad then they could b just constintly sprayin fuel into the cylinder rite???which in thery wld slide past the piston and into the oil right???and flooding the motor out which could make it cut out at 3000 rpms???how do i tell if the injectors are bad???
