KA24de Problem
Airmanspecial
Car: 1990 240sx
Me and a buddy picked up a 1990 240sx, the motor starts and runs ok after 3k rpms...but from idle to 3k it bogs down sputters..what have you.we are experianced aircraft mechanics with lots of auto expierinace but cant figure this guy out. we have adjuted timing to stock(20 degrees) cleaned out the fuelinjectors replaced cap rotors and wires, re gapped sparkplugs, checked for vacum leaks. cleaned maf tb......all the tlc that one would expect to do on a car with anew owner we have done... could this be a problem with the coil? or a fuel pump problem...right when we open the throttle quickly it almost dies...we have to coax it to higher rpms but even then it hesitates. it idles fine cold it jumps up to 1200 ish rpms then drops to 7-800 when it warms up. but comin on the throttle with the slightest load makes it wann die out without alot of milkin...i was also thinkin transmission kickdown(its an automatic...for now..) if someone can help trouble shoot id apreciate it, were not to familiar with these motors Thanks!
grecco28
Car: 1992 240sx
check the basics first
fuel pressure, coil resistance, spark(sufficient strong), inyector resistance,timming..
if ok, check maf outpup voltage, throtle pos voltage..
good luck...
Airmanspecial
Car: 1990 240sx
i still need to check fuel pressure(left my gage at home..)but i dont think that would be a prob since she screams after 3k rpms.., where can i find the specs on coil and injector MAF and TPS voltage?
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
Also a check for codes, before you keep going and can help you go in the right direction sometimes
