KA24DE power steering lines
biosehnsucht
We got the lines installed but where does the front / bottom bracket bolt to? Is there a difference afer minor change that it has a place to bolt to? theres some bolt holes in the brace that goes from the side to the radiator support, that looks like it could bolt on, but the spacing (too close) and size (too big) won't work.
Did anyone who swapped the P/S lines from a KA24DE figure out how to bolt that up, or did you just zip tie it or do nothing?
float_6969
I assume you had a KA-E before? If so, I had the same problem. I got the bracket to bolt up, but it was a pita and I think I had to cut/bend it.
ca18detizzle
same question, anyone have the answer?
RMiller
Car: BBQing
I did the same as Ryan. It takes awhile to get it right, but you'll get it.
