KA24DE power steering delete
MR.chris
Car: 1995 Nissan 240sx se SR20DET Money Pit
I bought a 1991 s13 and swapped a 1995 s14 engine in it, but the car did not have power steering ( lines or pump ) when I got the car, So I just have the power steering pump mounted as a tensioner for the water pump. How long will the pump last without oil? Has anyone else done this before? Does anyone have a better solution?
Creepy Cruiser
Are you going to be running A/C still? If not, then this is how I did mine.
http://forum.ratsun.net/showth...t+mod
zerepdivad
Car: '90 240sx . '02 Lexus IS300
I just use a 275k4 belt and cut a rib off and run a sohc waterpump pulley and i'm good. Just run it from the waterpump pulley to the crank and you're good. it stays nice and tight.
MR.chris
Thanks for the info. What will happen if I keep using the pump with no fluid in it? Is the power steering fluid used as a lubricant? I am not sure.
zerepdivad
Not sure. My friends power steering sprung a leak and he drove it with no fluid for a very long time and it never seized or anything.
MR.chris
Has anyone else experinced this?
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
My ps system's been leaking for a few months now, I just pour a little in there every now and then. It continues to work fine which amazes me lol
Oh, I glanced at this site, does this really work? How would get the tension correct?
http://www.club-s12.org/forums...22918
MR.chris
Well I have used it for more than a month with no oil and its still good, so i guess its going to work.
