KA24DE power steering delete belt
Somers Racing Innovations
Car: 1991 Nissan 240sx
Hey guys/ My friend has blown his power steering pump and is looking to eliminate the pump all together. He needs to know if anyone knows how long the belt must be to go from crank pully to water pump only or a part number would be great to.Thanks in advance.Peter
Razi
Car: Moo
Grab some string and find out.
allaboutspeed
Car: 1991 nissan 240sx
you cant really bypass the power sterring pump because of the pully itself. the power sterring pump is also used as the tensioner for the water pump and crank belt. you could take the pump off and take the back off the pump and remove the pins inside the pump and that will allow the pump to free spin.
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
I made a custom bracket to lower the alternator so I can run one belt. It took about an hour and some machine work and welding, but it looks so clean. You can sort of see it in the pic.
carps13guy
Car: 91 coupe ka
spank044 wrote:I made a custom bracket to lower the alternator so I can run one belt. It took about an hour and some machine work and welding, but it looks so clean. You can sort of see it in the pic.
damn man, that ka is mean as hell! if i wasnt such a broke *** college student i would do the same thing. is that intake mani custom or did you buy from someone? btw sorry to thread jack
spank044
I made it and it cost $7 dollars for the aluminum and some time. This setup ran 11's on 27psi. I will do a build thread some day, but never have the time.
