Unstock240 »
https://forums.nicoclub.com/unstock240-u100913.html
Wed Jan 13, 2010 8:07 am
My ka24de runs really fast until about 25 minutes of driving. When this happens it just seems as if im giving it only about 80% gas. Lots of new parts Cap, rotor, plugs, fuel filter, different ecu, injectors, another tps.Changing the tps helped most of the hesitation.
Note my valve seals need replaced. When I had the header off all the exhaust valves looked drippy. It hasnt burned any oil in 1k miles that I can tell. Can leaky valve seals cause power loss? I'm thinking when oil thins out in about 25 minutes maybe? My compression numbers are within 5psi, so no problem there.
