SimpleEnigma »
https://forums.nicoclub.com/simpleenigma-u14504.html
Thu Oct 06, 2005 6:13 am
If you are going to run NA, since this is what i am doing, i would definately do the standard I/C/H/E, spark plugs and wires, advance the base ignition timing, E-fan conversion, short shifter, new clutch, lighweight flywheel, LSD.
P&P is a pay-for-what-you-get type thing. Each machinist costs different amounts, depending on what you get done. Also, do research into the shop you use, some guys who dont really know what they are doin can really f-up your motor if the job isnt done correctly. just call up a couple of different places, see if they even offer what you need and go from there.
Lastly, the KA24E pistons, when put into a KA24DE motor, raise the compression to 11.1:1 CR, one of the guys on here, DeviousKA, sells them at HybridKA.com. but you would essentially have to run at least 91 octane fuel, if you dont already do so, and would net you a good deal of torque and hp combined witht the other mods.
