TrunkMonkey »
https://forums.nicoclub.com/trunkmonkey-u454.html
Sat May 15, 2004 10:30 pm
oem pistons do have different grades, but only for the stock bore. it tells how to determine which grade to use in the FSM.
there's no need to worry about grades when you overbore. send your oversized pistons to the machine shop with the block. they will bore each cylinder to fit a respective piston. if you assembly it yourself, make sure they are clearly marked so you don't get them mixed up.
-demetrius
